18" Stock Wheels vs 20" Optional Wheels For Mostly Suburban Driving???
Tazbom
5
7
Los Angeles County
I am shopping for a 2025 Land Cruiser LC. I would be driving is almost exclusively on Southern California suburban streets (80%) and freeways (20%). The only time I may need 4WD is an occasional trip to local mountains during the winter. I would like a wheel that handles well and provides safety in my mostly dry and smooth conditions, enhances gas mileage, is comfortable to drive on, looks good, and isn't cost prohibitive in the long run. If you possess good knowledge here, please answer the following questions with regard to the stock 265/70R18 vs the $1240 optional 265/60R20 wheels...
1. Do these two rims look the same? The website does not provide good pictures of the stock rims and none of the optional rims. Are they of similar quality?
2. What are the plusses and minuses of each wheel with regard to my needs.
3. Which do you feel would be better for my needs? If you feel the 20" would be better for me, would they be worth the $1240 additional cost?
Hi Tazbom, my 2025 LC has the stock 265/60R20 and I test drove a 2024 FE with 265/70R18. Most of my recommendations are qualitative and not quantitative. Assuming everything equal, i.e. same wheel and tire width (265), same total wheel+tire diameter:
265/60R20 (large wheel, slim tire)
Pros:
  • Better on-road cornering stability
  • Sexier look
Cons:
  • Generally more expensive tires (lower profile)
  • Worse mpg (more and larger metal, less rubber and thinner rubber = larger rotational inertia = more energy to spend for acceleration)
  • Slower acceleration
  • Stiffer on rough terrain
265/70R18 (smaller wheel, thicker tire)
Pros:
  • Generally cheaper tire
  • Better mpg (opposite argument as for the larger wheels)
  • Faster acceleration
  • Cushier on rough terrain
  • More badass look
Cons:
  • Worse cornering stability
These are the theoretical differences. In reality, the quantitative differences between the two configurations are small. And for the look, well thatโ€™s truly subjective. Since you said that you will be driving 100% on the road, including the mountains (snow on mountain roads is still driving on the road), perhaps the 20โ€ wheels better suit you.
That said, I recently bought my 2025 LC with 20โ€ wheels. I was looking for a LC with 18โ€ wheels and couldnโ€™t find one in the State of California. Apparently, Toyota decided that all 2025 LC trims in California are fitted with the 20โ€ wheels (I swear, I stalked 90% of the dealers in CA), only the 1958 trim was fitted with the 245/70R18 (also, weird tire size). So since you live in CA, as for your profile, if you want the 18โ€ wheels either get a 1958 trim or prepare to spend the extra $1240 for the 20โ€ wheels and then spend extra money for aftermarket 18โ€ wheels + tires too.
I was lucky enough to get a 2025 LC LC 18 in wheels in a local Toyota dealer (Toyota of Orange, Orange County) a few weeks ago. There were two trucks LC LC with 18 in and 20 in. I referred to 18 in wheels as the cons Gettleman said above.
20โ€ wheel:
18โ€ wheel (Land Cruiser trim):
I think both look good. I wanted 18โ€ for better offroad.
I donโ€™t think the difference will be noticeable in your case. Unless you really like the looks of one over the other Iโ€™d just find the Cruiser with the other options you want and you donโ€™t have to worry about which wheel option it has.
I have both wheels.
The distributor equipped our LC trim with the optional 20โ€ wheels, and I bought a second full set of 18โ€ stock wheels for a First Edition from another member on here.
If there is any practical difference in handling or fuel economy I havenโ€™t noticed it. The Land Cruiser is a 5300-ish lb brick shaped 4X4 with a compliant suspension made for general purpose off road driving and on road driving. Nothing you do is going to turn it into a performance car, or an economy car. If you consistently find yourself exploring the limits of lateral grip between the 18โ€s and 20โ€s on a Land Cruiser you picked the wrong vehicle.
The only difference in tires between my two wheel sets is that the 18โ€s are wearing dedicated snow tires, 265/70/R18 Michelin X-Ice Snowโ€™s, and the 20โ€s are still rocking the stock Dunlops. Same exact rolling diameter and width.
The 18โ€s look better in my opinion, and they ride a bit better having more sidewall. The better ride quality is something that is beneficial every day in 99% of your daily use. The same will apply to upgrading to a more off road oriented tire, the 18โ€ is going to soak up bumps just a bit better and probably provide a bit more forgiveness in resisting damage to wheels, and sidewalls with the extra compliance.
My vote therefore is; if you can choose, choose the 18โ€s.
To me, the 20โ€ is the better look by far and if you are driving primarily if not exclusively on suburban roads and highways the performance will be as good if not better than 18s. The ride may well be a bit firmer than 18s due to having a shorter sidewall but thatโ€™s a good thing โ€” subjective, of course.
I have both wheels.
Did anyone try 285/65 R20 tires on 20" stock rims 7.5" width, and on stock suspension ??
And by the way, did you try 285/65 R20 tires on 20" stock rims 7.5" width, and on stock suspension for instance ??
Two points - one is if you buy a LC base you may have a hard time finding 18 in rims. I had to get the 20 in rims I didnโ€™t want and pay for them. Being in demand the dealers are allotted certain builds and itโ€™s take it or leave it.
Second is I found a deal on 18 in. take offs and swapped them out for the 20โ€™s and put Nokian Outpost Nat 18 in tires were cheaper and more variety. Donโ€™t notice much of a difference on road so far re noise or handling but look better than the stupid Camry tires it came with. I live in Colorado so got them for snow and dirt roads here.
Buy what you want both are good.
Put Michelin Defender LTX on stock size, good to go for anything you described and more. Run at the door PSI, i think its 33 or 34 psi.
Don't make such a big deal out of nothing if you go top rate on the tries.
I suspect that OP has made a purchase decision considering they made this post half a year ago.
