I changed my mind over suspension lift because of the price involved and the need to do an alignment.
Since I cannot get the ICON wheels with 40mm offset, should I use 1” spacers?
www.spidertrax.com
The offset on my stock wheels is 70mm so with spacers it will be 45mm.
I’m guessing the result will be very similar, yes or no?
www.landcruiserforum.com
Toyota/Lexus 1 in. Thick Blue Wheel Spacers
35” K03 on stock tiny wheels, no lift!
Just want to share my experience with others in case you are in the same situation as me. The wheels I wanted are back ordered until spring (ICON with 40mm offset) so I decided to go with the stock 18” x 7” wheels with 70mm offset. I choose the K03 285/75R18 instead of the 285/70R18 because...
