Where are the TRUNK mounting points? Want to add a plywood sheet ie Goose Gear style?
The goose gear platforms are bolted down where the metal ‘cage’ is bolted. That is to say, the bottom of the cage’s legs where they meet the floor. Nothing on the goose gear is bolted to the top of the cage/battery
Seeing that now. Like a million steps to install that thing. :/
Hoping to just throw plywood over the trunk and bolt in a few places.
Here’s a thought, assuming you removed the back row seats:
Plywood board, 6 4x4s. 4 of the 4x4s go over the bolted legs, two go at the front of the bed all the way to the floor. Drill through the 4x4s that are over the battery bolts, then screw down with some real long bolts. Voila
You can check out my build thread for my platform. I unbolted the tie down latches near the rear seats and bought longer bolts to do exactly what you are talking about. It works great and is incredibly solid.
I have successfully added a direct link to my build page, if you would like to do the same for your build page;
Navigate to your build page and copy the "URL"
Edit your profile "signature" and paste the "URL" .......... done deal.
