Picked her up from Nashfabco with their full upcoming kit. Available for pre-order now is the rear half ladder, ditch light brackets, full length roof rack and rear side Molle Panels, and all these are 10% off during the first week!
IMG_6251_jpg.JPGIMG_6254_jpg.JPGIMG_6256_jpg.JPGIMG_6276_jpg.JPGIMG_6261_jpg.JPGIMG_6263_jpg.JPGtempImageWR0eGC.png
Looks fantastic!! Do you have any images of the ditch lights at night?
Have you any noticed a big difference with them on?
Truth be told those lights were put on for the marketing phots and then taken right off. I don't have anything mounted to them currently but am hoping for that to change after some Black Friday shopping! What I can say is that without the roof rack light bar it's almost complete silent. With the cutout you get more wind noise (far less than my previous rack) but it is not intrusive and does not whistle.
I too am very curious about when you add ditch lights and the noise levels. Keep us posted please. Looks great!
Nashfabco finished the ditch light brackets and rear half ladder. It retains use of rear glass which is awesome! Roof Rack is cut and should be powder coated Friday if final assembly goes well. Rear Molle Panels will be finished this weekend, I should have the build back on Monday or Tuesday and will update y'all then.
Can you share how these mount to the LC? I looked at your website and just want to understand before I purchase.
It slots in where the plastic trim pieces were originally as a one for one replacement. Those are held in with OEM bolts and these reuse those, so there is no new drilling needed whatsoever.
I might have to pick up those brackets for my GMRS antenna. I don't like the hood lip mount I have right now long term.
On their site they say for lights and accessories including antennas, but it seems I might have to drill the bracket for an antenna. Thoughts?
For as much as I write here about new suspension and tires etc, I finally made the first modification today, 1500 miles and 2 months in.
Removed the front air dams. Looks much better.
Baby got new shoes 👟! Installed set of 5 Nitto Terra Grapplers G3 A/TS in 275/70 R18 SL on stock FE rims. No poke at all which is what I wanted. Haven't noticed any appreciable increase in road noise or lowered ride quality. Taking them off-roading this weekend. Early days yet but seems promising.
Not a ditch light but a pretty neat conversation light at camp......
Click the image to play the video.
I like it! I have this same design puddle light for all 4 doors, will have to add this one for the back. Where did you get it and where does it go? I did not see an obvious spot for it in the back hatch...
Completely a DIY mod. I took apart one of the door projector lights, cut off the mounting tabs. I drilled a hole in the hatch switch panel the same size as the clear lens but not as big as the black plastic lens housing. I made an alum ring with a inner diameter the same as the round lens housing and "JB" welded it to the switch panel. The lens fits snugly in the alum ring and the actual LED and circuit board sits on top of that etc.... It sits at an angle on the plastic switch panel, so I filled the angle with JB Weld.
