Vehicle Stability Control (VSC) Message in 4Low
Doomed
105
214
Nebraska
2024 Land Cruiser 1958
OK, I know this has been talked about but I cant find it when I search. This stupid "VSC Turned OFF..." when in 4Low message keeps coming back even if you dismiss it. Has anyone found a way to kill? What a dumb design when you are "off-roading" to have a message that is persistent when you want/expect those systems to be tuned off. I really thought there was a way to kill it.
Put the vehicle in neutral, push on the button on the center console and put it in 4hi.
That does nothing to help the situation as the message happens in 4Low and I want to be in 4Low.
Yes! I knew this was talked about, I just could not remember how to defeat it. Thank you @lcq you rock!
Reactions: lcq
Got the same issue and can’t go away. The car drive very slow. I will call roadside assistance to take to dealership.
Is there a way to also turn off the warning that Traction Control is off? I can make the VSC off message disappear, but TC off won’t stop popping up.
