I am not sure how many people may need this but I did a short video of how I connected my relay/fuse box up on my LC. Hopefully this may answer someone's questions. This video is for people that want to use actual switches in the dash verse’s using smart switch modules. Some of the same stuff in this video can be used for both in reality. If you have any questions fire away. One thing I did forget to mention in the video is that I made little number tags to mark the circuits so I could tell what yellow and white wire goes to which circuit in the relay box. I put those tags on both the rely box end as well as in the inside of the vehicle too. In the description of the video as well as below the video is the item's I used in this install.
Item’s Used For This Install:
Relay/Fuse Box - https://www.amazon.com/Nilight-Pre-...Automotive/dp/B0CLJF43CN?ref_=ast_sto_dp&th=1
60 Amp Circuit Breaker - https://www.amazon.com/dp/B07PBGMMNZ?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
Fuse Taps - https://www.amazon.com/dp/B08QJHXRN6?ref=ppx_yo2ov_dt_b_fed_asin_title
Heat Shrink Butt Connectors - https://www.amazon.com/dp/B073RMRCC3?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
Buss Bars - https://www.amazon.com/dp/B0CC1DV4V4?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
Battery Terminal Covers - https://www.amazon.com/dp/B0D6XT3C5X?ref=ppx_yo2ov_dt_b_fed_asin_title
Heat Shrink Connectors - https://www.amazon.com/dp/B07ZPF1TTX?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
20-22awg Posi-Tap -https://www.amazon.com/dp/B001MPW54G?ref=ppx_yo2ov_dt_b_fed_asin_title
Wire Harness Tape - https://www.amazon.com/dp/B0821HLWCC?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
20awg Multi Color Wire - https://www.amazon.com/dp/B07TGJGJGD?ref=ppx_yo2ov_dt_b_fed_asin_title
16awg White Wire - https://www.amazon.com/dp/B09DSQ3RBB?ref=ppx_yo2ov_dt_b_fed_asin_title
16awg Red Wire - https://www.amazon.com/dp/B09DSQL4L3?ref=ppx_yo2ov_dt_b_fed_asin_title
16awg Black Wire - https://www.amazon.com/dp/B09DSNGYMD?ref=ppx_yo2ov_dt_b_fed_asin_title
12awg Yellow Wire - https://www.amazon.com/dp/B09DSQVRXP?ref=ppx_yo2ov_dt_b_fed_asin_title
Heat Shrink Gun - https://www.amazon.com/dp/B08VFY8THD?ref=ppx_yo2ov_dt_b_fed_asin_title
Crimpers - https://www.amazon.com/dp/B0D3D2RTY4?ref=ppx_yo2ov_dt_b_fed_asin_title
