Pretty sure they don't. The under hood jumper point is protected by a 350a fusible link (located under the red plastic cover by the battery) which probably will blow under the amp draw from a winch under heavy use.Where does toyota recommend power supply for winch?
MY thoughts are I will have to run wires from battery in back to front with some sort of fuses ?
