Any one by chance have access to the procedure/ instructions for the OEM rear skid plate installation? I'm sure I could muddle my way through but I do like my instructions.... haha
Please show what it actually looks like than just the boxI ordered mine through toyota and they confirmed it as a fit for my LC. Just need to bolt it on. Came with some rubber pieces that i assume are ment to dampen the unit to avoid vibrations ect View attachment 28060
I'll take some pics and weight when I get home today. For science ! I briefly took it out of the book yesterday and I would estimate about 5-7 lbsPlease show what it actually looks like than just the box
What’s the weight of it? 3/16” steel ?
The RCI rear diff skid (3/16” thick steel) is about 22 lbsI'll take some pics and weight when I get home today. For science ! I briefly took it out of the book yesterday and I would estimate about 5-7 lbs
That's the front and transmission skid plates. There is now a third skid plate that covers the rear diff, which a few folks have ordered and hopefully we'll see their easy installs soon!Here you go! I installed both a few weeks ago. This PDF covers both. The instructions that came with it were pretty useless.
The rear is easier than the front, although the only real issue I had with the front was figuring out the configuration of the bracket on the front plastic trim.
Nice! can't wait to see it and hear about a simple and easy installI ordered mine through toyota and they confirmed it as a fit for my LC. Just need to bolt it on. Came with some rubber pieces that i assume are ment to dampen the unit to avoid vibrations ect View attachment 28060
Oh my badThat's the front and transmission skid plates. There is now a third skid plate that covers the rear diff, which a few folks have ordered and hopefully we'll see their easy installs soon!
Thanks for all detail photos.Received my Skid Plate today, no instructions in the box sadly, but all the hardware was there. Seems pretty straightforward. The U-Brackets just wrap around the Diff (rubber in-between) for a nice snug fit.
Note that the U-Brackets & rubber in them are slightly angled to match the skid plate angle, as pictured below.
Will install this weekend. View attachment 28505
View attachment 28503View attachment 28504View attachment 28506
3. Remove Brake Line Bracket
(a) Using a 12mm Socket, Remove 1 bolt from the rear brake line bracket. Retain bolts for re-installation (Fig. 3-1).
(b) Using a 12mm Socket and 12mm Wrench, remove 2 bolts from the rear brake line bracket. Retain bolts for re-installation (Fig. 3-2).
