***New CA Tuned Offroad Front Bumper***
Luigi
34
67
San Jose, CA
2024 LC250
CA Tuned Offroad front bumper for the LC250.
CAtuned Off-Road 2024+ Land Cruiser Front Bumper
*Integrated bar to run whatever lights you want
*”wing” brackets support that viper style cut for higher clearance
*net weight of 89 lbs with bumper & winch combo
*2 inch receiver for multiple mounting applications
*front camera relocation
That looks pretty good. Wonder if the Nacho Grande lights would fit where the two baja designs lights are mounted.
Described as a "bolt-on solution" but wonder how much, if any, cutting is involved for installation?
Theres cutting involved but not much more than the other front bumper options available in the market. It’s actually all plastic trim that you’ll need cutting so super easy.
I don’t see that being a fitment issue. I’m running two LP6’s and have plenty of clearance for the wire harness and space overall.
At 89lbs incl the winch, would this cause the front end to sag? Would I benefit from a Westcott spacer kit to bring the nose up? Not looking for a ton of height gain as I still want to fit in the garage with the Yakima fatcat up top.
Thx!
There are probably a couple ways you can do so, but one option will be a license plate holder for the front 2 inch receiver. I will take pictures on how that would look like and post on here.
I am from CA too, and never had front license plate on my Gwagon, Tesla, and now LCFE
I saw hundreds (if not thousands) luxury vehicles and exotic ones have no front license plates.
However, depending on the county you live…Los Angeles is terrible one that will enforce that “law”. My Orange County is “free” ;)
Actually, it is your choice with pros and cons
Happy LC
Thx!
100% fitting through the garage 7’ standard height door. I had 2 “ lifted rear, leveled front, 35” tires, and OEM FE roof rack. With that “massive tall”, my LC still have 2” clear
I had similar dv8 centric steel bumper and 12k lbs winch, roughly same weight 80 lbs added in. From the look (before I lifted), It sags down a bit, but not noticed difference while driving with handling performance. Definitely, you need some kind of “lift” ( from “basic” Westscott to “fully” King shocks (like mine)
I had similar dv8 centric steel bumper and 12k lbs winch, roughly same weight 80 lbs added in. From the look (before I lifted), I sag down a bit, but not noticed difference while driving with handling performance. Definitely, you need some kind of “lift” ( from “basic” Westscott to “fully” King shocks (like mine)
Thanks, thinking the Westcott might do the trick. I’ve got 265 Toyo AT3s (10ply) on it now and will keep these for a couple years until I burn through them, at which point I’ll put 275 or 285s on. Not quite ready for the MPG hit and I like keeping the ski rack mounted to the FE rack while still fitting in the garage.
I messaged CA Tuned for more info so I’ll see what they say on the install and will share.
Happy LC
I live a block from a town with a PD that loves to enforce stuff like that unfortunately!
