Hello folks!
soon to be a new 2025 LC owner in Heritage Blue / Grayscape roof.
as it is my duty to frustrate the missus... thinking of wheels and tires and just have some questions and confirmations.
If so, from this thread
www.landcruiserforum.com
seems i can go more conservative with a 275/70/R18 tires (approx 10.83 wide, 33" diameter)
the wheels i'm interested in are Icon Alloys Rebound (Bronze/Black Lip) or Icon Alloys Compression (Bronze/Black Lip), both with +25mm offset
would these would be the appropriate sizes for the wheel/car?
BF Goodrich All Terrain T/A KO3 (LT265/70 R 18)
Falken Wildpeak A/T4W (LT 265/70 R 18)
now the part that concerns me is that the thread i've linked above specifies a wheel with +40mm offset whereas the wheels i've selected are +25mm offset.
Thanks in advance for your replies,
Al
note: calculated tire diameter from google search result as: Tire Dia = (Tire With x Aspect Ratio)/1270 + Rim Diameter
Will 18" x 9" +40mm offset work on LC (Base Trim)?
Will a 18" x 9" +40mm offset wheel work on the LC (Base) Trim with stock suspension and height with no rubbing? I'm considering 275/70/R18 tire size. Is anyone running an 18" (or 17") x 9" wheel with a +40mm offset, can you post photos?
Al
