NEED INFO - Lugs & torque spec for the upgraded Tacoma TRD wheels PTR5635242F1
ycart1201
46
25
Oregon
2024 Toyota Land Cruiser 1958 Edition 2023 Toyota Tundra Limited TRD Off Road
Does anyone know the LUG SIZE & TORQUE SPECS for upgraded Tacoma TRD wheels PTR5635242F1 ?
I’m asking because I want to get black lugs and I want to swap them out myself but don’t know the lug size or mfg recommended torque spec for those wheels.
Thanks in advance!
Bump. Looking to purchase the black lugs as soon as I get confirmation on lug size.
Wheel lug nut torque specs would be available in the Tacoma TRD owners manual, which I would think is available on the Toyota website.
Edit: Yep, here is the 2024 Tacoma owners manual: https://assets.sia.toyota.com/publications/en/om-s/OM04042U/pdf/OM04042U.pdf
And it says 97 ft/lb for aluminum wheels.
Wheel nut torque:
Steel wheels: 154 ft•lbf (209 N•m, 21.3 kgf•m)
Aluminum wheels: 97 ft•lbf (131 N•m, 13.4 kgf•m)
Wheel nut torque:
Thanks! I had no idea toyota had the manual online. 97 ft lb it is. 😎
97ft-lbs is pretty much the default Toyota alloy wheel torque spec on just about everything.
Good to know, thank you. Any idea what the lug size is for the LC or Tacoma?
I know I can reuse the chrome lugs from the LC but think I’d want to buy black lugs.
