Multiple Instrument Gauges Malfunctioning
Daniel Key
2
0
Christiansburg, Va
2006 Toyota Landcruiser
Hi, this is Danny in Va.
I have a 2006 Toyota Land Cruiser with only 69,900 miles on it. Last Friday, 3 of the instrument gauges began malfunctioning. Simultaneoulsly, the voltage guage pegged to 13+ volts, the Fuel Guage peggeded as far below E as possible, (although I had just filled up the tank with gas), and the Oil Pressure Guage increased to within 1/8 inch of H. I had the alternator tested by Advance Auto and by a reputable garage. Both independently reported it was putting out 13.49 volts. I also found an electrical schematic of all fuses and verified that all fuses that appeared to related to guages were good via Ohm meter. I also disconnected the battery and reconnected it, but it had no effect. Today is Monday and the guages are still malfunctioning.
Although the guages are malfunctioning, the vehicle runs fine. It is currently in a shop being diagnosed at $100/hour and the owner says it may take them days to find the root cause.
Has anyone ever had this happen to them and/or does anyone have any ideas what the problem might be (or perhaps it is multiple problems?)
Thank you for your feedback,
Danny
