Lowering Option?
LC-FJM
๐Ÿ“› Founding Member
Oct 2, 2024
Toronto
2024 LC FE
I have a new FE and really enjoying my first week of driving.
I want it to be a daily commuter as well as my weekend ride, and unfortunately it does not fit in the parking garage at my office. The roof rack hit the ceiling and I need atleast 2 inches more clearence. I am considering taking the rack off but wanted to hear opinions on if it is worth trying to lower the suspension to get it to fit?
What is the most efficient way to do this?
Could it be on an air system that changed height only when I needed to park?
If it was not adjustable would it compromise the ride?
Thanks
Air ride would do what you want, but I think it would be costly as it would be a custom install.
Might be cheaper to fab some quick disconnect mounts for the rack.
I would lower it as a last resort. The half shafts are perfectly aligned at stock height. Vulcanized-on bushings are also set to normal ride height. You lower it, and the half shafts now articulate every time you go down the road, and your bushings are experiencing constant load, even at rest.
Prepare some sand bag/water container in your office garage...
Will slowly wear your springs and tires though
