Hybrid System Malfunction
aliddell
6
Colorado
Hi. Anyone experiencing hybrid system malfunction. This morning on my way to work this message popped up. In process getting it into dealership. 2024 LC
You are not alone... second time I have had this happen to me (September and last Saturday) at exactly the same location... going down Floyd's hill on westbound I70... very fun place for a car to go into limp mode.
  • Hybrid system malfunction
  • Drive-Start Control Malfunction
  • System Malfunction
  • Check engine
Just received word that Toyota told the dealership to replace the high pressure fuel pump.
Anyone have any experience or wisdom when it comes to this part? How big of an issue is this? Long-term issues caused by this part malfunctioning? Is this serious enough to start pushing for a new LC because of potential damage to the engine etc.
Any thoughts would be appreciated.
  • Check engine
I had all those lights initially but now only the hybrid system malfunction light. I’m at dealership now
  • Check engine
Generally this isn't too bad of a job. It can require lowering the gas tank to access the pump. Sometimes manufacturers are brilliant and have an access panel in the cargo area. However, I bet that isn't possible in the LC250 because of the hybrid battery. There are probably other things that make the job more difficult as well.
Is that the only fuel pump we have on these vehicles, or is there also maybe a low pressure one still in the tank?
Especially right now with no shoulder on either side and the road surface awful from the construction. Glad you’re safe!
Why does the message say hybrid system malfunction if the code is for the fuel pump?
  • Check engine
Drop the fuel tank and replace the pump, not very complex if the tanks empty........ a little tricker if the tank's full.
