Husky Hood Air dam
Area 51
491
368
NorCal
2025 Land Cruiser, Jeep TJ built.
Played with the Husky kit a bit just now. Installed the light bar in the air dam molded area, it can't be left empty.
Threw all the wiring and sticky crap away, everything. What a mess and useless set up the lighting is.
It mounts just above the black front edge mni dam that is stock and attached to the hood.
Here is a before and after, the dam is only set in place, not sure if ill use it or not yet. The back has a 360 deg sticky tape set up, thats all that holds it on, i have mixed feelings about that. Looks ok to good. Not CV or even close, degrades the gorgeous paint job. Way overpriced, but what's new.
Not sure how effective this thing is vs nothing. So far no complaints on the freeway aerodynamics. This could easily become a useless item.
Before and after pics for your entertainment.
That looks interesting, can you share a photo pulled back a little bit further if you have the time (or when you have the time)?
Did not install, too much sticky crap not sure it will stay on.
The other one on another thread is way better.
