Help with Drive-Start Control System & Check Engine Messages
Wake Up To Adventure
2
Bend, Oregon
2025 Land Cruiser
Hey Everyone,
I just left a local tint shop and when starting my car I have multiple messages popping up including Drive-Start Control System and Check Engine. Based on the time when the codes popped up matches when the tint shop said they hooked up a trickle charger to the terminal under the hood. I am able to drive the car but clearly the hybrid system is not working. I have scoured the forums and have seen removing the negative terminal in the back can reset the computers after 15 minutes but that didn't work for me. Any thoughts and suggestion are greatly appreciated as I am supposed to leave for Yellowstone tomorrow morning. A side note, when I opened the hood, I found the fuse panel completely open with out the cover being replaced.
Trickle charger shouldn't have cause this as I have had mine on a under-hood trickle charger many times. (dependent on what/where they did under the hood)
Absolutely agree, with you that shouldn’t have caused it. I tried unplugging the negative terminal again and let the car sit without power over night and this morning I turned on the car and all the alerts have gone away. Very strange but happy to report that the car seems to be running ok.
I wonder if they put on the trickle charger and disconnected the battery?
“Drive start control system” sounds like the backup starter, so maybe it threw a code since battery was disconnected.
This happened to me about ten days ago in mine. It’s been sitting at the dealer ever since. I’ve been told it’s an emissions sensor that triggered it of which there are no current replacements available. One month into ownership haven't even made the first payment on it yet.
Were they able to discern what the issue was with yours?
@scottgibson-LC25 - did you ever get a resolution to this? I’m in a similar situation.
My tint guy just finished and I am getting the same message. I wonder if it was just because he had the ignition on for a long time. Going to try to disconnect the negative terminal to see if it solves it. Perfect timing as the long weekend is coming up and I have a photo shoot this weekend. As long as it drive's I can live with it until next week.
