Fog light fuse location
rsbarton
๐Ÿ“› Founding Member
Jul 16, 2024
15
Ontario Canada
2024 First Edition
I have a first edition and i tried my fog lights the other night and noticed that they did not come on , nor did the dash switch light up. Does anybody know what fuse box it is located in( under hood or passenger side inside) and under what name? I could not see anything name specifically fog etc. They did work on delivery so i thought i would check the fuse first but cannot locate the correct one.
Thanks in advance
Here's the wiring dia..... Are you sure your headlight's aren't on bright? Fog lights are only enabled on the "dim" setting.
  • Fog Light.pdf
sorry i am kind of new - looking at your wiring diagram ( thanks again) am i reading it correctly that the fuse is in the under the hood box and number 5
Thanks again
It doesn't appear to have a dedicated fuse per-say.
It's controlled by the Main Body ECU.
The (5) means it's the #5 pin on the connector
My bad, figured out that i did not have the fog light turned on - on the stock , just the headlight switch
soon as turned that all good- thank you and sorry about my "moment"
No worries! at least it was a cheap fix......LOL
