🛠️ Member Build DV8 Center Molle console, Victory 4x4 Molle Lift gate, Receiver Skid Plate
Member Build
Bappy
103
90
Arizona
2024 Toyota Landcruiser
Did some work on the rig this weekend and thought I would share a couple of things:
DV8 Molle Center Console, First the thing came packaged incredibly well. Fully Wrapped in Spongy packing sheets. This may have been the best packaging I have seen. The Panels are very well made and heavy duty compared to everything else I have ordered. Install in about 15 min for both sides. What you need to know. The instructions are straight forward but needs some tweaking. I have the Mid tier cruiser the front portion of the center console is soft touch. You cannot just drill or the material behind will bind up and rip your material on the outside. Mark the holes with a paint pen then you need and exacto knife the kind that Hobby people use. You need to use the knife to make small incisions to cut away the soft inside material so it does not bind up on the drill bit. The panels are stout and looks great.
Victory 4x4 Molle lift gate panel. Is straight forward. instructions are good. no surprises installs in about 20 min and looks great.
Receiver skid plate was my way of trying to cover the shitty job that Toyota did with the bumper. I think it is stout and looks good. Can be purchased here:
