Dongar PRO Dashcam Adapters.. ELIMINATE messy wires and add PARKING mode to your dashcam!
Dongar
đź“› Founding Member
đź›’ Supporting Vendor
May 30, 2024
16
31
NorCal
2024 Land Cruiser FE
Hi LC forum!
Introducing our latest product... Dongar PRO! This novel USB adapter converts your rearview mirror (or plugs into the 5-pin OEM dashcam adapter in the domelight cavity) into a power source for your dashcam or USB device, all in under 5 minutes :cool:. Not only does this mean hiding messy wires, your dashcam stays ON after you've shut the vehicle off, thanks to intelligent parking mode!
How does this work?
Toyota/Lexus provides both constant-on and ignition-switched wires to the mirror to power the garage door buttons. In the 4G Tacoma, new Land Cruisers, new 4Runners etc, they’ve even provisioned a power connector specifically for dash cams. Our USB buck converter provides 5V/9V/12V output over its USB-C port continuously via the constant-on and reads it to monitor your truck's battery voltage. The ignition-switched wire is read out to determine when the vehicle is on, or if there’s an over voltage condition, etc.
What are the features?
The adapter has 3 modes:
1) ignition: your dashcam turns on and off with your Tacoma’s ignition
2) continuous: your dashcam stays on all the time, as long as your truck’s 12V battery is above the low-voltage protection threshold. This was designed to minimize draining your battery below engine cranking levels.
3) timed mode: keeps your dashcam powered on for 4 hours after turning the ignition off. There’s many use cases for this, but one example is when you tend to park you car in the garage at night/weekend and therefore don’t need true 24/7 parking mode except when you go in errands around town, and on average most vehicles are parked in public parking lots less than 4hrs at a time. The 4 hour timer resets each time you turn the ignition off.
How do you install it??
The Dongar PRO module sticks directly onto your windshield.
What's included?
We include 3 different wiring harnesses: 12pin, 5pin, and 10pin. The Land Cruiser has a 10pin connector at the rearview mirror and a 5pin connector in the domelight cavity (this is actually provisioned from the factory to use the Toyota OEM dashcam!)
Available now on Amazon and our homepage Dash Cam Install Easy as 1..2..3..
