Finally made a choice on rear shelf. My buddy had bought this for his Ineos and loved the quality. Rack is solid and I trust will hold up well.
Pros:
Cons:
Overall I love it and seems to be the best and cleanest setup available with no permanent modifications required. Shipped from Poland and arrived in 5 days from order and was about $500 shipped to my door.
Pros:
- Quality: Seems like great quality, powder coat was excellent
- Build: Single piece shelf which was a must for me and molle panels that allow access on back side
- Storage: Awesome slightly adjust shelf (about 1” up/down) plus under shelf option for more storage
Cons:
- Vibration: I do see a slight vibration in shelf when driving when shelf is empty. Not likely unique to this shelf, but it’s there. When comparing with the Ineos bracket, I see this one hangs down lower from mount points and that’s likely to accommodate rear hatch roof line dropping down a lot on LC. They need shelf to be low enough to load gear.
- Rattle: when pairing with molle side panels, they do not have a combined bracket setup, you overlay the molle and shelf bracket and screw down. I was getting some minor rattle noise and solved it by placing these little felt pads between parts where it’s metal on metal. Completely silent now. I also noticed a bit of noise where lower molle bracket connects at the bottom, the bracket makes slight contact with plastic trim so placed a few felt pads on bracket where it contacts plastic. Keeps plastic from getting damaged and also stops any rattle noise.
